citanie s jrmi:
13:45:29.421: [E5 07 01 49 42 41 56] Uhlenbrock IB-COM / Intellibox II Start Programming Track.
13:45:29.427: [82 7D] Set Global (Track) Power to 'OFF'.
13:45:29.489: [ED 1F 01 49 42 71 72 03 00 00 70 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 67] Read CV in Direct Byte Mode from PT for Uhlenbrock IB-COM / Intellibox - CV: 3.
13:45:31.718: [E7 0E 7C 00 00 00 00 07 00 00 0E 00 00 63] Programming Response: Uhlenbrock IB-COM / Intellibox II Programming Read Was Successful: CV1 value 14 (0x0E, 00001110b).
Programmer error: Timeout talking to command station (306)
cistanie s ovladacom daisy2:
13:45:35.054: [E5 07 01 49 42 41 56] Uhlenbrock IB-COM / Intellibox II Start Programming Track.
13:45:35.057: [82 7D] Set Global (Track) Power to 'OFF'.
13:45:37.501: [ED 1F 01 49 42 71 72 03 00 00 70 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 67] Read CV in Direct Byte Mode from PT for Uhlenbrock IB-COM / Intellibox - CV: 3.
13:45:39.751: [E7 0E 7C 00 00 00 00 07 00 00 0E 00 00 63] Programming Response: Uhlenbrock IB-COM / Intellibox II Programming Read Was Successful: CV1 value 14 (0x0E, 00001110b).
2020-01-11 22:26:18,625 loconet.SlotManager DEBUG - readCV(string): cvNum=3 mode=Direct Byte [AWT-EventQueue-0]
2020-01-11 22:26:18,626 loconet.SlotManager DEBUG - readCV: 3 [AWT-EventQueue-0]
2020-01-11 22:26:18,627 uhlenbrock.UhlenbrockPacketizer DEBUG - add to queue message E5 07 01 49 42 41 00 [AWT-EventQueue-0]
2020-01-11 22:26:18,628 uhlenbrock.UhlenbrockPacketizer DEBUG - queue LocoNet packet: E5 07 01 49 42 41 56 [AWT-EventQueue-0]
2020-01-11 22:26:18,629 uhlenbrock.UhlenbrockPacketizer DEBUG - end wait [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,629 uhlenbrock.UhlenbrockPacketizer DEBUG - check for input [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,629 uhlenbrock.UhlenbrockPacketizer DEBUG - add to queue message ED 1F 01 49 42 71 72 03 00 00 70 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [AWT-EventQueue-0]
2020-01-11 22:26:18,630 uhlenbrock.UhlenbrockPacketizer DEBUG - start write to stream [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,631 uhlenbrock.UhlenbrockPacketizer DEBUG - queue LocoNet packet: ED 1F 01 49 42 71 72 03 00 00 70 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 67 [AWT-EventQueue-0]
2020-01-11 22:26:18,632 uhlenbrock.UhlenbrockPacketizer DEBUG - end write to stream [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,632 loconet.LnPacketizer DEBUG - message transmitted (echo false) [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,649 uhlenbrock.UhlenbrockPacketizer DEBUG - Start message with opcode: e5 [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,653 uhlenbrock.UhlenbrockPacketizer DEBUG - We have our returned message and can send back out our next instruction [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,659 uhlenbrock.UhlenbrockPacketizer DEBUG - queue message for notification [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,659 uhlenbrock.UhlenbrockPacketizer DEBUG - check for input [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,660 uhlenbrock.UhlenbrockPacketizer DEBUG - Start message with opcode: 82 [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,661 uhlenbrock.UhlenbrockPacketizer DEBUG - start write to stream [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,662 uhlenbrock.UhlenbrockPacketizer DEBUG - queue message for notification [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,663 uhlenbrock.UhlenbrockPacketizer DEBUG - end write to stream [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,668 loconet.LnPacketizer DEBUG - message transmitted (echo false) [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,669 loconet.LnTrafficController DEBUG - notify of incoming LocoNet packet: E5 07 01 49 42 41 56 [AWT-EventQueue-0]
2020-01-11 22:26:18,670 loconet.LnTurnoutManager DEBUG - LnTurnoutManager message E5 07 01 49 42 41 56 [AWT-EventQueue-0]
2020-01-11 22:26:18,674 loconet.LnTrafficController DEBUG - notify of incoming LocoNet packet: 82 7D [AWT-EventQueue-0]
2020-01-11 22:26:18,675 loconet.LnTurnoutManager DEBUG - LnTurnoutManager message 82 7D [AWT-EventQueue-0]
2020-01-11 22:26:18,719 uhlenbrock.UhlenbrockPacketizer DEBUG - Start message with opcode: ed [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,724 uhlenbrock.UhlenbrockPacketizer DEBUG - We have our returned message and can send back out our next instruction [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,724 uhlenbrock.UhlenbrockPacketizer DEBUG - queue message for notification [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:18,724 uhlenbrock.UhlenbrockPacketizer DEBUG - check for input [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,725 uhlenbrock.UhlenbrockPacketizer DEBUG - start wait [LocoNet Uhlenbrock transmit handler]
2020-01-11 22:26:18,730 loconet.LnTrafficController DEBUG - notify of incoming LocoNet packet: ED 1F 01 49 42 71 72 03 00 00 70 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 67 [AWT-EventQueue-0]
2020-01-11 22:26:18,731 loconet.LnTurnoutManager DEBUG - LnTurnoutManager message ED 1F 01 49 42 71 72 03 00 00 70 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 67 [AWT-EventQueue-0]
2020-01-11 22:26:20,957 uhlenbrock.UhlenbrockPacketizer DEBUG - Start message with opcode: e7 [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:20,963 uhlenbrock.UhlenbrockPacketizer DEBUG - queue message for notification [LocoNet Uhlenbrock receive handler]
2020-01-11 22:26:20,981 loconet.LnTrafficController DEBUG - notify of incoming LocoNet packet: E7 0E 7C 00 00 00 00 07 00 00 0E 00 00 63 [AWT-EventQueue-0]
2020-01-11 22:26:20,982 loconet.LocoNetSlot DEBUG - notify 0 SlotListeners [AWT-EventQueue-0]
2020-01-11 22:26:20,982 loconet.SlotManager DEBUG - notify 1 SlotListeners about slot 124 [AWT-EventQueue-0]
2020-01-11 22:26:20,983 loconet.SlotManager DEBUG - LOCO_ADR resp is slot 124 for addr 0 [AWT-EventQueue-0]
2020-01-11 22:26:20,983 loconet.SlotManager DEBUG - no request for addr 0 [AWT-EventQueue-0]
2020-01-11 22:26:20,983 loconet.SlotManager DEBUG - Prog Message 0xe7 for slot 124 in state 1 [AWT-EventQueue-0]
2020-01-11 22:26:20,983 loconet.LnTurnoutManager DEBUG - LnTurnoutManager message E7 0E 7C 00 00 00 00 07 00 00 0E 00 00 63 [AWT-EventQueue-0]
2020-01-11 22:26:26,629 loconet.SlotManager DEBUG - timeout fires in state 1 [AWT-EventQueue-0]
2020-01-11 22:26:26,630 loconet.SlotManager DEBUG - timeout while programming [AWT-EventQueue-0]
2020-01-11 22:26:26,630 loconet.SlotManager DEBUG - notifyProgListenerEnd with 14, 128 and _usingProgrammer = CvValue _num=3 _cvName= [AWT-EventQueue-0]
sidlo píše:Jakým způsobem bylo prokázáno, že spojení mezi počítačem a centrálou Uhlenbrock funguje?
2020-01-15 23:15:15,446 apps.AppsBase INFO - DecoderPro version 4.16+R6f9aced starts under Java 1.8.0_241 on Windows 7 amd64 v6.1 at Wed Jan 15 23:15:15 CET 2020 [main]
2020-01-15 23:15:17,479 gui3.Apps3 INFO - Starting with profile DaisyIIUhlenbrock_63120.3d0c2bf6 [main]
2020-01-15 23:15:18,110 node.NodeIdentity INFO - Using ce9a1b83-2f39-43d2-98e0-3d5e98d2f9cf as the JMRI storage identity for profile id 3d0c2bf6 [AWT-EventQueue-0]
2020-01-15 23:15:18,266 xml.AbstractSerialConnectionConfigXml INFO - Starting to connect for "LocoNet" [main]
2020-01-15 23:15:18,977 uhlenbrock.UhlenbrockAdapter INFO - Uhlenbrock adapter set no flow control, mode=0 RTSCTS_OUT=2 RTSCTS_IN=1 [main]
2020-01-15 23:15:18,978 locobuffer.LocoBufferAdapter DEBUG - Serial timeout was observed as: 10 enabled: true threshold: 0 enabled: false [main]
2020-01-15 23:15:18,980 locobuffer.LocoBufferAdapter INFO - COM1 port opened at 57600 baud with DTR: true RTS: true DSR: false CTS: false CD: false [main]
2020-01-15 23:15:18,981 locobuffer.LocoBufferAdapter DEBUG - port flow control shows no flow control [main]
2020-01-15 23:15:18,982 loconet.LnPortController DEBUG - setCommandStationType: Intellibox-II [main]
2020-01-15 23:15:18,982 loconet.LnPortController DEBUG - turnout no retry: false [main]
2020-01-15 23:15:18,983 loconet.LnPortController DEBUG - turnout extra space: false [main]
2020-01-15 23:15:18,985 uhlenbrock.UhlenbrockPacketizer DEBUG - UhlenbrockPacketizer instantiated [main]
2020-01-15 23:15:18,986 loconet.LnCommandStationType DEBUG - attempting to create jmri.jmrix.loconet.UhlenbrockSlotManager [main]
2020-01-15 23:15:18,991 loconet.LnTrafficController DEBUG - getSystemConnectionMemo LocoNet called in LnTC [main]
2020-01-15 23:15:18,992 loconet.LocoNetSystemConnectionMemo DEBUG - ThrottleTransmitted configured with: false [main]
2020-01-15 23:15:18,992 loconet.LocoNetSystemConnectionMemo DEBUG - set turnout retry: false [main]
2020-01-15 23:15:19,011 loconet.LocoNetSystemConnectionMemo DEBUG - GetThrottleManager for Intellibox-II [main]
2020-01-15 23:15:19,011 loconet.LocoNetSystemConnectionMemo DEBUG - getThrottleManager constructs for Intellibox-II [main]
sidlo píše:Není LocoNet jako LocoNet (stejně jako není XpressNet jako XpressNet). Někteří výrobci si přidávají do zobecněných řešení vlastní kurvítka tak, aby znemožnili jiným firmám se s nimi domluvit. Například Uhlenbrock zavedl pro programování LNCV. Na to prodává licenci a kdo ji nemá, tak má s produkty Uhlenbrock problémy. Například RocRail pomocí reverse engineering podporu implementoval a na zásah Uhlenbrock ji musel se svého SW odstranit. Podpora Uhlenbrock nekomerčním projektům (jako např. JMRI) je nulová. Záměrně neposkytují žádné informace.
Moje zkušenost s IntelliBox je následující. Spojení centrály přes USB kabel je neskutečně pomalé. Když se ta samá centrála připojí přes stařičké rozhraní LocoBuffer http://www.locobuffer.com/ spojení funguje bezvadně. Jinak řečeno – koupit drahé zařízení přímo od Uhlenbrock nemusí být výhodou.
Zpět k rozhraní 63120. Chyba 306 znamená, že rozhraní neodpovídá. Pokud všechno ostatní funguje a jediné co nefunguje je programování tak to může znamenat, že rozhraní z nějakého důvodu filtruje pakety. Problém potom není v DecoderPro ale v 63120. Potom bych doporučil přečíst manuál k 63120 a zjistit, zdali se na něm nedá nastavit nějaký jiný mód, který by umožnil přenášet všechny LocoNet pakety přes interface. Je to jenom moje hypotéza, skutečný problém může být jinde.
Mafo píše:Skusil som uz vsetko mozne a nepomohlo. Par prispevkov dozadu som aj pridal vypis z Loconet monitoru a porovnal pakety nacitania CV cez JMRI a cez ovladac. A su rovnake. Mozno by bolo dobre porovnat komunikaciu z LocoBuffera (pri nacitani napr. CV3)...
Long_ACK: Uhlenbrock IB-COM / Intellibox II CV programming request was accepted.
Programming Response: Uhlenbrock IB-COM / Intellibox II Programming Read Was Successful: CV1 value 2 (0x02, 00000010b).
Uživatelé procházející toto fórum: michal_n_cz a 1 návštěvník
