JMRI
Re: JMRI
Příspěvekod sidlo » ned 23 srp, 2020 7:36 am
Píše to Time out. Počítač a interface spolu nemluví.
Re: JMRI
Příspěvekod belgarat » ned 23 srp, 2020 7:38 am
Coudo: az Ti JMRI vyhlasi chybu, otevri prosim okno s nastavenim spojeni na Tvou NanoX, a udelej screenshot toho okna (kvuli presnemu nastaveni). Pak otevri ve Windows ovladacich panelech seznam zarizeni (kde budou videt i ty COM/USB porty), a opet screenshot, pro jistotu.
EDIT: u nastaveni JMRI prosim zaskrtni "Doplnkova nastastaveni", aby se zobrazily i podrobnejsi volby.
Ja osobne NanoX 2.4 neznam, zacinal jsem az v roce 2015 :) na fotce je nepatrne videt cosi bileho co muze byt USB konektor -- je tam, nebo je mezi centralou a PC jeste nejaky 'mezikus' ?
http://modelwiki.klfree.net
Re: JMRI
Příspěvekod Čouda » ned 23 srp, 2020 9:20 am
Belgerat:
Pro kontrolu screeny obrazovek.
https://imgup.cz/image/krk7
https://imgup.cz/image/krkO
https://imgup.cz/image/krka
a tady LOG:
0 apps.AppsBase INFO - ****** JMRI log ******* [main]
795 apps.AppsBase INFO - This log is stored in file: C:\Users\Miroslav\JMRI\systemfiles\messages.log [main]
827 util.Log4JUtil INFO - ****** JMRI log ******* [main]
827 util.Log4JUtil INFO - This log is stored in file: C:\Users\Miroslav\JMRI\systemfiles\messages.log [main]
951 apps.AppsBase INFO - DecoderPro 3 version 3.0-r20870 starts under Java 1.8.0_261 at Sun Aug 23 11:08:43 CEST 2020 [main]
6132 li100f.LI100Adapter INFO - COM3 port opened at 9600 baud with DTR: true RTS: true DSR: true CTS: false CD: false [main]
36396 lenz.XNetInitilizationManager WARN - Command Station disconnected, or powered down assuming LZ100/LZV100 V3.x [main]
41403 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 21 21 00 consecutive timeouts = 0 [Transmit]
76472 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 21 24 05 consecutive timeouts = 1 [Transmit]
122893 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 21 80 A1 consecutive timeouts = 2 [Transmit]
157946 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 21 80 A1 consecutive timeouts = 3 [Transmit]
Čouda
Re: JMRI
Příspěvekod belgarat » ned 23 srp, 2020 10:23 am
Fajn, preinstaluj / nainstaluj nove JMRI. Porad je to z verze 3.0, ta je tak historicka, ze k ni nemam vubec zadne info :)
Re: JMRI
Příspěvekod Čouda » ned 23 srp, 2020 10:50 am
Log teď vypadá takto:
rozdíl je v tom, že DSR nyní píše false, ale CD je již true. Problém je někde v komunikaci, nehledal bych to v programu ani ve špatném nastavení. Jenže tohle už je nad moje síly.
2020-08-23 12:42:00,775 util.Log4JUtil INFO - ****** JMRI log ******* [main]
2020-08-23 12:42:01,321 util.Log4JUtil INFO - This log is appended to file: C:\Users\Miroslav\JMRI\log\messages.log [main]
2020-08-23 12:42:01,337 util.Log4JUtil INFO - This log is stored in file: C:\Users\Miroslav\JMRI\log\session.log [main]
2020-08-23 12:42:01,399 apps.AppsBase INFO - DecoderPro version 4.20+Rc7ba8249b starts under Java 1.8.0_261 on Windows 7 x86 v6.1 at Sun Aug 23 12:42:01 CEST 2020 [main]
2020-08-23 12:42:02,881 profile.ProfileManager INFO - Created default profile "Moje JMRI železnice" [main]
2020-08-23 12:42:03,521 gui3.Apps3 INFO - Starting with profile Moje_JMRI_železnice.3d5236d8 [main]
2020-08-23 12:42:03,755 apps.AppsBase INFO - No pre-existing config file found, searched for 'C:\Users\Miroslav\JMRI\Moje_JMRI_železnice.jmri\ProfileConfig.xml' [main]
2020-08-23 12:42:03,755 util.FileUtilSupport INFO - File path program: is C:\Program Files\JMRI\ [main]
2020-08-23 12:42:03,755 util.FileUtilSupport INFO - File path preference: is C:\Users\Miroslav\JMRI\Moje_JMRI_železnice.jmri\ [main]
2020-08-23 12:42:03,755 util.FileUtilSupport INFO - File path profile: is C:\Users\Miroslav\JMRI\Moje_JMRI_železnice.jmri\ [main]
2020-08-23 12:42:03,755 util.FileUtilSupport INFO - File path settings: is C:\Users\Miroslav\JMRI\ [main]
2020-08-23 12:42:03,770 util.FileUtilSupport INFO - File path home: is C:\Users\Miroslav\ [main]
2020-08-23 12:42:03,770 util.FileUtilSupport INFO - File path scripts: is C:\Program Files\JMRI\jython\ [main]
2020-08-23 12:42:07,733 node.NodeIdentity INFO - Using 12e2540b-7c14-4b31-a8a7-387f635403d7 as the JMRI storage identity for profile id 3d5236d8 [main]
2020-08-23 12:42:07,748 managers.JmriUserPreferencesManager INFO - No saved user preferences file [main]
2020-08-23 12:42:49,945 li100f.LI100fAdapter INFO - COM3 port opened at 9600 baud with DTR: true RTS: true DSR: false CTS: false CD: true [Start-Up Wizard Connect]
2020-08-23 12:43:20,022 lenz.XNetInitializationManager WARN - Command Station disconnected, or powered down assuming LZ100/LZV100 V3.x [Start-Up Wizard Connect]
2020-08-23 12:43:20,880 logix.WarrantPreferences ERROR - _fileName null. Could not create warrant preferences file. [Start-Up Wizard Connect]
2020-08-23 12:43:25,030 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 21 21 00 consecutive timeouts = 0 in lenz.XNetPacketizer [lenz.XNetPacketizer Transmit thread]
2020-08-23 12:44:00,083 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 21 24 05 consecutive timeouts = 1 in lenz.XNetPacketizer [lenz.XNetPacketizer Transmit thread]
2020-08-23 12:47:55,846 jmrix.AbstractMRTrafficController WARN - Timeout on reply to message: 22 15 01 36 consecutive timeouts = 2 in lenz.XNetPacketizer [lenz.XNetPacketizer Transmit thread]
Čouda
Re: JMRI
Příspěvekod sidlo » ned 23 srp, 2020 11:10 am
Píše to samé co verze 3.0. Timeout -- rozhraní nekomunikuje.
Re: JMRI
Příspěvekod belgarat » ned 23 srp, 2020 12:02 pm
Nekomunikuje ... ale proc :) Neprijemne je toto:
Mne nabiha s 'true' ... a jestli zustava CTS stale false, tak JMRI neposle ani n~.
Muzes, coudo, zkusit:
- v JMRI pustit XpressNet (hlavni menu) -> XpressNet Monitor
- na MM (jinem ovladaci) udelat STOP
... co se ukaze (jestli vubec neco) na tom monitoru ? Pokud se objevi spravna zprava, tak je port a JMRI nastaveny asi dobre ... chybu bych pak hledal v HW. Nebo zkusit jiny ovladac; mas ten original od FTDI ?
Re: JMRI
Příspěvekod Čouda » ned 23 srp, 2020 12:06 pm
Již jsme za pomoci kolegy Petra Šídla problém vyřešili:
Vše bylo nastaveno správně až na jeden detail, který není na první pohled zřejmý. Z nějakého důvodů se centrála do XpressNet přihlašovala pod adresou 00. Správně by mělo být 29. Pomocí programu Hyperterminál, byla tedy nastavena správná adresa a vše již funguje. Petrovy patří veliké díky za trpělivost.
Pokud by něco podobného řešil ještě někdo jiný, je třeba se nezaleknout, že hyperterminál nereaguje na klávesy PC. Není to pravda. Je třeba naslepo naťukat dccdcc a zmačknout enter. Poté je již vše v pořádku. Podrobnější návod najdete zde:
https://rmf31.fr/telechargement/Manuelgenlis88.pdf
Čouda
Re: JMRI
Příspěvekod Čouda » čtv 27 srp, 2020 5:18 am
Dobré ráno. Za vydatného přispění kolegy Petra Šídla, jsem naučil spolupracovat mobilní telefon, JMRI, NanoX přes wifi. Komunikace probíhá přes domácí router, který do celého bytu rozvádí internet.
Níže dám jednoduchý obrázkový návod:
1) Je nutné spustit WiThrottle server, volbou z obrázku.
2)Takto vypadá spuštěný server. Povšimněte si čísla IP adresy a portu
3)Zde již pohled na WiThrotle s přihlášeným ovladačem.
Čouda
Re: JMRI
Příspěvekod Čouda » čtv 27 srp, 2020 5:22 am
4) Pohled na přihlašovací obrazovku do programu Engine Driver. Tento program je volně ke stažení na GooglePlay. Zde máme možnost připojení k již vyhledané síti nebo parametry zadáme ručně.
Smyslem těchto příspěvků je ukázat, že i s NanoX a Jmri za pár šlupek jsme schopni dosáhnout výsledků, jako s placeným profi vercajkem. Je na každém, co si kdo zvolí.
Více podrobností o Engine Driveru naleznete u Petra zde:
https://sites.google.com/site/sidloweb/ ... withrottle
Čouda
JMRI - počet uživatelů
Příspěvekod sidlo » úte 10 lis, 2020 12:03 pm
Nedávno tu byl učiněn pokus o porovnání počtu uživatelů jednotlivých systémů podle počtu uživatelů v příslušném fóru http://diskuze.modely.biz/viewtopic.php?f=26&t=10666&p=238232#p238230.
Repozitář github poskytuje statistiky stažení jednotlivých verzí JMRI. To se vydává dvakrát ročně. Na začátku letních prázdnin a na začátku Vánočního volna. Poslední produkční Vánoční verze přesáhla 30.000 stažení.
Re: JMRI
Příspěvekod Trixt » úte 10 lis, 2020 6:57 pm
No jo, on počet stažení, na rozdíl od počtu uživatelů, vůbec o ničem nesvědčí. Všichni, co chceme využívat nějaký software pro řízení kolejiště, si JMRI stáhneme, stejně tak jako například RocRail nebo demoverzi TC apod. To ale neznamená, že ten konkrétní program daný uživatel opravdu pro řízení kolejiště používá. Vypovídací hodnota toho grafu je spíše o tom, jakému typu instalace uživatelé dávají přednost.
Trixt
Re: JMRI
Příspěvekod sidlo » úte 10 lis, 2020 7:32 pm
Vypovídací hodnota toho grafu je, že trend je rostoucí :D
Re: JMRI
Příspěvekod Trixt » úte 10 lis, 2020 7:46 pm
Ano, s tím souhlasím, stále více železničních modelářů opouští analog a stále více modelářů uvažuje o řízení kolejiště pomocí nějakého programu. Ten rostoucí trend bude pravděpodobně pozorovatelný i u ostatních programů. ;)
Trixt
Re: JMRI
Příspěvekod look23 » úte 10 lis, 2020 9:13 pm
sidlo píše:Vypovídací hodnota toho grafu je, že trend je rostoucí :D
Já tam vidím, že je vždy vyšší zájem v druhé polovině roku způsobené startem modelářské sezóny.
Rostoucí trend jde vypozorovat jedině u verze programu :D
H0, ČSD epocha IV, V - z21+MM
Zpět na Software
