Zimo Instruction manual píše:The motor and function outputs of ZIMO decoders are designed with lots of reserve capacities and are additionally protected against excessive current draw and short circuits. Cut-outs are encoun-tered if the decoder is overloaded.
All ZIMO decoders are equipped with temperature sensors to measure their own operating temperature. Power to the motor will be turned off once that temperature exceeds 1000C. The headlights start flashing rapidly, at about 5 Hz, to make this state visible to the operator. Motor control will resume automatically af-ter a drop in temperature of about 200C, typically in about 30 seconds.
Hribajs píše:sejmutí spodního krytu podvozku je tady.
viewtopic.php?f=16&t=12133
jestli chceš vyloženě čistit styk podvozku a rámu tak musíš- sundat kastli,
-odšroubovat dps a asi i odpájet
-pak už vidíš pojistku, která drží podvozek v rámu-roztáhnout a podvozek vypadne
Uživatelé procházející toto fórum: Kavka_ a 1 návštěvník
