Lasoft píše:Tak toto dostanu těsně poté co tam vrazím GENLI-USB. Na něm se rozsvítí červená ledka a nic víc se neděje. Jo a jak mám nechat ROCRAIL běžet aby bylo vidět v okně. Co má být ve spouštěči? Jsem s Linuxem začátečník hold![]()
radek@RLLOKO:~$ dmesg | tail -25
[ 527.200319] usbcore: registered new interface driver ftdi_sio
[ 527.204605] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 527.208729] ftdi_sio 2-3:1.0: FTDI USB Serial Device converter detected
[ 527.208875] usb 2-3: Detected FT232BM
[ 527.208879] usb 2-3: Number of endpoints 2
[ 527.208882] usb 2-3: Endpoint 1 MaxPacketSize 64
[ 527.208885] usb 2-3: Endpoint 2 MaxPacketSize 64
[ 527.208888] usb 2-3: Setting MaxPacketSize 64
[ 527.213339] usb 2-3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 2492.399213] usb 2-3: USB disconnect, device number 2
[ 2492.399608] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 2492.399649] ftdi_sio 2-3:1.0: device disconnected
[ 2926.843364] nouveau [ DRM] Calling LVDS script 6:
[ 2926.843367] nouveau [ DRM] 0xD3BF: Parsing digital output script table
[ 2927.142769] nouveau [ DRM] Calling LVDS script 2:
[ 2927.142773] nouveau [ DRM] 0xD424: Parsing digital output script table
[ 2927.273727] nouveau [ DRM] Calling LVDS script 5:
[ 2927.273729] nouveau [ DRM] 0xD3A8: Parsing digital output script table
[ 2928.460198] nouveau [ DRM] Calling LVDS script 6:
[ 2928.460206] nouveau [ DRM] 0xD3BF: Parsing digital output script table
[ 2928.762124] nouveau [ DRM] Calling LVDS script 2:
[ 2928.762132] nouveau [ DRM] 0xD424: Parsing digital output script table
[ 2928.893089] nouveau [ DRM] Calling LVDS script 5:
[ 2928.893092] nouveau [ DRM] 0xD3A8: Parsing digital output script table
[ 3582.608188] perf interrupt took too long (2512 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
radek@RLLOKO:~$
fulda píše:Pokud má centrála propagaci změny polohy (MM myslím má), tak se ta informace dostane do PC...
Použij mojí testapp na místo terminálu, ta ti to bude ukazovat rovnou v přijatelně čitelné podobě.
Martinovo píše:Tu propagaci zmeny polohy maji i centraly zalozene na NanoX ??
