exiftool mojefoto.jpg >mojefoto txtExifTool Version Number : 10.49
File Name : IMG_20240822_114642.jpg
Directory : .
File Size : 3.3 MB
File Modification Date/Time : 2024:08:22 12:30:28+02:00
File Access Date/Time : 2024:08:25 14:25:22+02:00
File Creation Date/Time : 2024:08:25 12:22:42+02:00
File Permissions : rw-rw-rw-
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Camera Model Name : TCL 40 NXTPAPER 5G
Orientation : Horizontal (normal)
Modify Date : 2024:08:22 11:46:42
Compression : JPEG (old-style)
Y Cb Cr Positioning : Centered
F Number : 1.8
Warning : [minor] Unrecognized MakerNotes
Exposure Time : 1/50
Resolution Unit : inches
Sub Sec Time Digitized : 789
Sub Sec Time Original : 789
Sub Sec Time : 789
Focal Length : 4.2 mm
Flash : Off, Did not fire
ISO : 148
X Resolution : 72
Y Resolution : 72
Create Date : 2024:08:22 11:46:42
Exif Image Height : 2160
White Balance : Auto
Date/Time Original : 2024:08:22 11:46:42
Exif Image Width : 3840
Components Configuration : Y, Cb, Cr
Color Space : sRGB
Exif Version : 0220
Make : TCL
Thumbnail Offset : 553
Thumbnail Length : 31056
JFIF Version : 1.01
Image Width : 3840
Image Height : 2160
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Aperture : 1.8
Image Size : 3840x2160
Megapixels : 8.3
Shutter Speed : 1/50
Create Date : 2024:08:22 11:46:42.789
Date/Time Original : 2024:08:22 11:46:42.789
Modify Date : 2024:08:22 11:46:42.789
Thumbnail Image : (Binary data 31056 bytes, use -b option to extract)
Light Value : 6.8
alexander píše:Problém som vyriešil!
Mobilom treba fotiť "na šírku"a potom sa obrázky vložia so správnou orientáciou.
A ďakujem kolegom za snahu pomôcť!
