When I built the new boards for South Bohemia it left two 3'x2' boards from the original TTe layout that were no longer needed... Now that's two boards waiting for something to be done with them and I can't leave opportunities like that go to waste so I began to wonder what I could do with them... Originally I thought about extending South Bohemia with more scenery but the difficulty came with the space needed to transport the layout and the longer layout space needed at shows both of which I thought would not work...
So, a small 6ftx2ft "scenic" layout perhaps...
When on our Czech/Austria NG trip I introduced my friend David to Albeř, a small village just on the outskirts of Nova Bystrice near the end of the southern of the two JHMD lines. I had thought before it would make a good, compact, layout in HO but with the smaller size of TT I recon it will fit on the two boards... It consists of a small station with siding and a viaduct made of stone and girder construction... A visit to that exhibition in Prague where they had modelled it confirmed my opinion that it would make a neat compact model...
For a start the original only has a siding which will restrict working at exhibitions (assuming people want it), so it will have a loop instead. Secondly I'll be modelling at it from the other side to the Prague layout, they model it from the location of a Hostel, but I will be looking "uphill" towards the Hostel. The ground slopes upwards towards it so will help in disguising the back.
I've been wondering how to disguise the exit of the road 152 (see: https://www.google.c...5.1390126?hl=en) which is quite a wide road, even on that model they haven't managed it! On looking on page 141 of my book on the line (the Karel Just book!) it would appear that the small road under the single girder was originally the main road and the current 152 road under the second of the double girders didn't exist. If my reading of that page is right the twin girders actually went across the river/stream instead so they must have changed it when they built the new road (I assume to bypass Alber itself).
That rather makes things easier. If you look closely at that link you can see the water course does a sharp left hand turn and goes under the 152 and into the forest, it actually goes up to a large lake behind the forest. That would make life much easier for me modelling it as it naturally goes out of the line of view deep into the trees.
So my current thoughts are to get rid of the new road (the 152) altogether and take it back to pre bypass days. It would be handy to see some photos of it before this road was built but so far I haven't found any, can anyone help with old photographs of the viaduct?
